FYSETC SD-WIFI MK3s Issues
I've recently purchased a FYSETC SD-WIFI adapter to use with my MK3s to make transfering .gcode files easier.
The problem I've encountered is that if I transfer files over WiFi to the MicroSD card connected to the adapter (which is plugged in the MK3s), the printer does not see the new files until I remove and reconnect the adapter to the printer. I've also noticed an option to change the SD card mode to FlashAir, which gives me a "Refresh" option inside the "Print from SD card" menu, however, that does nothing. I've tested the adapter with other PCs and this doesn't happen, however, the printer refuses to re-read the contents of the card.
Postato : 08/02/2023 1:57 pm
