Fw glitch?
Dusk
 Dusk
(@dusk)
Fw glitch?
I found an interesting glitch, that has kept happening since the last couple firmware updates. When a print hits a certain percentage it shifts about a minor amount on the x axis, and about 5-10% more of the print then corrects back to where it should be. In addition when moving the x axis after it completes when you return it to the far point of the left it recenters the home spot. I have a picture here so you can see what I mean by the axis shift and return. Never had the problem prior to the updates.
Publié : 15/06/2020 6:44 pm
RE: Fw glitch?
Which firmware version are you seeing this with? 3.8x has known issues with the filament sensor enabled.
Publié : 15/06/2020 6:47 pm
Dusk
 Dusk
(@dusk)
RE: Fw glitch?
@bobstro
I'm on 3.9.0.
I didn't think it would be the filament sensor. Is it still a thing with 3.9 as well?
Publié : 15/06/2020 11:54 pm
RE: Fw glitch?
It is fixed in 3.9.
Publié : 16/06/2020 2:07 am
Dusk
 Dusk
(@dusk)
RE: Fw glitch?
I tried turning off the filament sensor, just to see what would happen, and it shifted the other way. I currently have another print running after reassembling the x axis and managing the belt tension and will see what happens.
Publié : 16/06/2020 11:49 pm
Dusk
 Dusk
(@dusk)
RE: Fw glitch?
So after re-enabling the sensor, I print a smaller print and it came out flawlessly. I then proceeded to try a larger one and it had shifted on the y axis.
Publié : 19/06/2020 3:03 am
