Fusion 360 and Prusa Control
Paul
 Paul
(@paul-12)
Hi Everyone,
I have just received my new Prusa i3 MK3 and I LIKE IT!!!
I have a problem with the connection from Fusion 360 directly transferring to Prusa Control.
In Fusion there is a box under FILE that says 3D Print. In this box you can direct the fusion Model to say Prusa Control, but I have done this and it finds Prusa Control but then stops. Has anyone tried this? i know this works in Fusion because it has presets for RepitierHost which I have used successfully before.
Postato : 09/06/2018 11:02 am
bozzo
(@bozzo)
Re: Fusion 360 and Prusa Control
Which OS are you on?
Postato : 11/06/2018 2:13 pm
LaPointe
(@lapointe)
French moderator and translator Moderator
Sorry, I never used Fusion 360 that way, I always export my designs in STL files then slice them.
Postato : 11/06/2018 3:25 pm
stephen.h14
(@stephen-h14)
I use Win10 and cannot export directly to PrusaControl but I can export directly to Slic3rPE with no problem. But I normally save the stl and import it myself.
Postato : 12/06/2018 6:43 am
