funny noise on my mk3+s extruder
Windowlick3r
(@windowlick3r)
Mitglied
During Live Adjust Z calibration it was laying down the filiment  at -1.175. But after a brief run of 7 or 8 perfect prints it crashed due to y calibration error.
So after recalibrating using the wizard option I noticed that it wasnt laying down the print lines without a thin line of filiment and a little blob right after the test line prior to printing. So I unloaded the filiment opened the extruder door and removed a small bit of filiment. Then I did a cold pull on it and thought it should be good. But a vibrating noise coming from the extruder coupled with a weird rough sound during printing. I noticed that quite a few alan bolts were loose all over the printer. I didnt tighten the bolts I assumed affected the XY and Z belts. figured they would need some special process or torque wrech or what have you to mess with.
Any thoughts on whats been asked here while I figure out how to post a link the video took of it?
Is -1.175 to -1.200 sound like a proper LA Z setting?
Any help with these questions will be greatly appreciated.
Thanks for now an
Veröffentlicht : 28/01/2024 10:46 pm
Brian
(@brian-12)
RE: funny noise on my mk3+s extruder
It all depends on where your super pinda probe is set for the z offset values so it's hard to comment if what you have is correct.
I set mine using a zip tie and with the satin sheet I'm at -1.950.
Veröffentlicht : 29/01/2024 12:48 am
