Full RX Buffer
Eddiie
(@eddiie)
Full RX Buffer
I upgraded to firmware 3.7.1 and about the same time Octoprint had a release too.  Not sure who to blame..  Googling says it is the USB cable but had no issues previous to these last changes..
Currently running  OctoPrint 1.3.11 running on OctoPi 0.15.1
MK3S MMU2S Single Color print
Has anyone experienced the following pause / lockup during a print job?   I see this in the Octoprint terminal window -
Send: N6985 G1 X129.128 Y105.000 E0.07355*81
Recv: Full RX Buffer
Recv: ok
Send: N10375 G1 X124.209 Y107.167 E0.00727*106
Recv: NORMAL MODE: Percent done: 72; print time remaining in mins: 3
Recv: SILENT MODE: Percent done: 67; print time remaining in mins: 3
Recv: ok
Sure enough, data flys / scrolls through on that terminal when it is running it is sort-of hard to capture the text around the incident, but I dont normally keep it open.
Here is another -
Send: N4038 G1 X118.541 Y110.695 E0.00857*85
Recv: ok
Send: N4039 G1 X117.908 Y111.328 E0.01671*83
Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
Send: N4040 M105*23
Recv: Error:Line Number is not Last Line Number+1, Last Line: 4035
Recv: Resend: 4036
Recv: ok
Send: N4036 G1 X118.159 Y111.712 E0.00855*91
Recv: ok
After about 15 or 20 seconds the print resumes.
Publié : 19/06/2019 2:47 am
