Flow Override Causing Major Motion Issues
Craboulas
(@craboulas)
I'm really struggling with the motion control of my new i3 MK3. I am finding that stealth mode, linear advance, and flow override all can contribute to bad motion of the extruder drive, the print head, or both.
Here is a photo that shows a progression of settings and the results:
Here is a video showing the extruder drive doing a retract type of move when approaching this very gentle arc. The printer is in stealth mode, and has K set to zero, and flow override set to 108%. Setting flow back to 100% completely "fixes" this gap in the print.
I have used Marlin based printers for 6 years and have never seen anything like this, even at silly high flow % values. Printer is running FW 3.4.
Publié : 25/09/2018 12:55 am
Craboulas
(@craboulas)
Re: Flow Override Causing Major Motion Issues
I took another video and actually found that what I thought was the print head slowing down, causing an over-extrusion bulge, is actually a completely erroneous move in Y axis:
As you can see, this part is just a giant square, with large corner radii. There should be no negative Y movement as it begins that corner.
Publié : 26/09/2018 7:30 pm
