Flexplate thickness vs Buildtak
I'm just wondering from a "maintaining zero" perspective if anyone has confirmed that the Prusa spring steel plate is exactly the same thickness as the Buildtak Flexplate? It would be great to be able to just swap them as and when (I could keep one for PLA and one for ABS) but I don't really want to have to mess with Z zero every time...
Thanks.
Postato : 04/12/2018 11:06 am
Re: Flexplate thickness vs Buildtak
I found a slight difference of about 0.2 or so depending on the surface you place on it. .
Postato : 04/12/2018 12:25 pm
