Flex build plate warping under print only
munkeyboy
(@munkeyboy)
So I have a knock-off textured steel build plate.  It feels quite thick, but the plate lifts/bubbles under the hotend. (i've verified, this moves with just the print area and can push down on the bubble).  Not always consistent, but suspect magnets have some effect here. Super odd, but since I don't have an official prusa, I can't buy the official plate.  It seems worse when bed temps above 60c and/or hotends above 215c (abs/petg).    PLA is ok, but i have other inconsistent prints here with what seems to be the pinda2 issues (1st layer inconsistent in random strips).
 Any suggestions of flex plate brands that won't do this?  Or is this an issue with something else?
Opublikowany : 12/11/2020 8:53 pm
RE: Flex build plate warping under print only
which build plate did you buy?  I own a lot.
Opublikowany : 21/11/2020 9:09 pm
