Flashing Error
JMHaro
(@jmharo)
Flashing Error
I've flashed my printer several times in the past but now I'm getting the following error and can't figure out what might be the issue.  Below is the log file.  It recognizes the printer when I connect my USB cable to it, I've tried resetting the printer a couple times and connected/reconnected the cable several times.  Any ideas?
avrdude: Version 6.3-20160220-prusa3d, compiled on Feb 11 2019 at 18:25:11
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/PROGRA~1/Prusa3D/Slic3rPE/resources\avrdude\avrdude.conf"
Using Port : COM5
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: ser_open(): can't open device "\\.\COM5": Access is denied.
avrdude done. Thank you.
Respondido : 20/01/2021 3:05 am
JMHaro
(@jmharo)
RE: Flashing Error
Well never mind.  I went ahead and rebooted my computer but also realized I was on 2.2.0 so updated to 2.3.0 and now it's flashing OK.  So it was either the update or the reboot, but it's flashing now successfully.
Respondido : 20/01/2021 3:21 am
