FIX: Blinking LCD for Prusa MK3S
Howdy. I came across an issue where the LCD on my MK3S would blink rapidly on power up of the printer. The issue were some shorted wires in the part cooling fan (See photo of area), the shorting of these wires can also cause the fan to stop working. This can be easily remedied by moving the wires with a small pointed object so they do not touch each other anymore (I used my pocket knife). I believe that if your printers LCD is blinking and one of your fans has stopped working that fixing the short in the fan will fix the printer. Also be sure to turn your printer off when doing this if you don't want any bigger issues.
Postato : 18/01/2023 12:33 am
