First print with FW 3.9.0
Eric
 Eric
(@eric-8)
Hi there! No pleasant reason for my first post but well..
During live Z - about two minutes after starting a new print.
Doesn't look healthy - but the printer kept printing. I even was able to scroll trough the menu, but everything was looking like on the image. I pressed reset after ~30 seconds.
Now I'm back on 3.8.1
Any ideas?
Veröffentlicht : 27/05/2020 9:11 am
Andrew
(@andrew-5)
RE: First print with FW 3.9.0
Worked fine on mine.
Only issue I had was a self inflicted crash test when the extruder hit my filament guide, you know the type...make it yourself....feel very proud ...then fit it the wrong way round...yes that type of guide. Instead of carrying on from where it left of it needed to be recalibrated from scratch. Including first layer and for me live Z worked fine. Have you tried another FW install and a different print file to narrow the problem down?
Andrew
Veröffentlicht : 27/05/2020 12:31 pm
rmm200
(@rmm200)
Some people have reported display problems on other releases when the error file for their language was missing - and they had an error.
Might double check that you installed the right language.
Veröffentlicht : 27/05/2020 3:25 pm
Eric
 Eric
(@eric-8)
Posted by: @andrewld
Andrew
I printed the same file on 3.8.1 without problems.  I won't play around and flash several FW versions unless I getting paid for it 😉
Posted by: @robert-rmm200
As I wrote: The issue came up a few minutes after I started the print job. First everything was looking as it should be - including the language. It changed DURING live Z. From normal to this mess.
Guess I will post this at GitHub, because it is clearly a FW problem. Something that shouldn't happen in any case regardless of what I do.
Veröffentlicht : 29/05/2020 1:23 pm
