First layer calibration loop
Kalimando Design
(@kalimando-design)
I recently had to take my top end apart to fix a small problem with a loose hotend, and upon rebuilding and calibrating the first layer calibrator gets stuck in a loop where it asks for filament to be inserted even when it has been in the same session. Should I reflash the latest update? Is there a hard reset?
Postato : 05/08/2020 11:01 pm
RE: First layer calibration loop
could your filament sensor be on the edge of working, and giving false signals?
there is a sensor spacer for the mk3S filament sensor
on thingiverse
check your sensor status
Postato : 05/08/2020 11:27 pm
Kalimando Design
(@kalimando-design)
I think you might be right, when I was rebuilding it I just looked up the EINSY board photo on the knowledge base. The filament sensor is the only thing I had some confusion about since it has no "keying" to its male end. I might have put it in left handed instead of right handed.
Postato : 06/08/2020 8:25 pm
