Firmwarechanges for longer Hotend to the MK3s
PPRRUUSSAA
(@pprruussaa)
when I attach another longer hotend to the Prusa MK3s, had I to change the firmeware, as I read in the internet (2014, 2016,2018 and early 2019) ? Or is it obsolete of P.I.N.D.A. Or can I only send some G-Codes to set the new Z-height?
Does anybody know? - Carsten
Napsal : 26/01/2020 12:42 pm
RH_Dreambox
(@rh_dreambox)
RE: Firmwarechanges for longer Hotend to the MK3s
If you make a change in the height of the nozzle, you need to adjust the PINDA (1 mm higher than the nozzle) and then do a new Z calibration.
If your new hotend end is much longer than the old one, there may be problems with the Z calibration because the printer wants to calibrate the working height to 210 mm.
Napsal : 27/01/2020 12:31 pm
PPRRUUSSAA
(@pprruussaa)
OK, I will try, we will see ... - Carsten
Napsal : 27/01/2020 4:45 pm
@umaker
If necessary you should change Z_MAX_POS (MK3S it's 210) in the firmware, compile and flash again (Reduce this value by the height difference from the original construction) otherwise you will get a calibration error:
file: configuration_prusa.h (renamed file from variants order)
#define Z_MAX_POS 210
For example: If you install a Bondtech Extruder you must change this value to 205, because the Bondtech is about 5mm different to the original Prusa Extruder.
Napsal : 27/01/2020 9:25 pm
PPRRUUSSAA
(@pprruussaa)
Everything is working fine :o) thx for help -> Carsten
It will be nice, If prusa will make it changeable with gcode-commands.
Napsal : 28/01/2020 12:04 am
