Firmware Update Warning
jandb150
(@jandb150)
Anyone know why my printer is asking me to update Firmware to 3.13.2, when I have 3.13.2-RC 7068 installed. Anyway  to get around this?
Thanks
Postato : 25/01/2024 2:20 am
Brian
(@brian-12)
RE: Firmware Update Warning
You should be able to just click past it.
Postato : 25/01/2024 5:09 am
Hello
(@hello)
Posted by: @jandb150
Thanks
I presume it's when you start a print. If so delete the bit of gcode in prusa slicer start gcode.
Postato : 25/01/2024 7:18 am
jandb150
(@jandb150)
Yeah, It's when I start a print. I'm sure you know this, but it doesn't affect anything, just annoying. It warns me on the printer and Ocotanywhere sends me a text message. So if I change the G code, will it stop forever, or is this something I will have to do every single time I run a new print?
Postato : 25/01/2024 2:47 pm
Hello
(@hello)
If you fo into prusa slicer under start gcode remove the line that says firmware check. That will stay forever if you save it.
Postato : 25/01/2024 6:50 pm
vd853
(@vd853)
Utenti
This is really bothersome.
Postato : 08/08/2024 1:58 pm
