Firmware Update fail
Knights
(@knights)
Hey guys, I'm trying to update the printer firmware to the latest 3.8.1 but while I'm checking the dialog box it keeps telling me it has failed as the "The semaphore timeout period has expired.". Now I have checked and made sure I'm on the correct COM Port and I have re-scanned for the printer multiple times, I have also changed to all of my different USB ports but I still get the same error. I'm just wondering if anyone else has come across this and found a fix.
Cheers
Postato : 14/01/2020 7:42 am
JustMe3D
(@justme3d)
RE: Firmware Update fail
Did you switch on the printer?
https://help.prusa3d.com/article/gXdRubco3u-firmware-updating-flashing-problems?
Postato : 14/01/2020 9:08 am
rmm200
(@rmm200)
Now that is just cruel...
But did you?
Postato : 14/01/2020 4:24 pm
Posted by: @tyson-b2
Cheers
Maybe a corrupt hexfile, network driver problems, Firewall blocks, try after fresh system reboot. If nothing works try the flash, if available, with a linux system. Use latest PrusaSlicer Update (2.1.0).
Postato : 14/01/2020 6:34 pm
Knights
(@knights)
@just3d
Lol, yes the printer is switched on
Postato : 15/01/2020 1:39 am
rmm200
(@rmm200)
Don't feel picked on. We have had users that did not realize that was required.
Postato : 15/01/2020 1:43 am
Knights
(@knights)
Ok, I have now downloaded the latest Slicer 2.2.0 and restarted my computer but I still can't get it to flash through Slicer. Is there another program I could use to flash it with?
Postato : 15/01/2020 2:30 am
Knights
(@knights)
Didn't Prusa have another firmware flasher before they integrated it into Slicer?
Postato : 16/01/2020 11:34 pm
Yes, but it doesn't handle the alternate languages
Postato : 17/01/2020 2:29 am
Knights
(@knights)
@joantabb
Ahh I see, thanks for that. I guess I'll just have to keep trying to figure out why all of a sudden it wont update the firmware.
Postato : 17/01/2020 9:58 am
@knights
Have you tried a different USB cable?
Postato : 17/01/2020 10:11 am
@knights
Does PrusaSlicer recognize the COM interface with the MK3? Which error message do you get exactly? A windows System error or a Slicer Flash error or no error message?
Postato : 17/01/2020 11:36 am
Knights
(@knights)
Hi Joan,
Yes I've tired a different USB cable, I have also tried different USB ports on the computer as well.
And Karl,
Yes Prusa Slicer recognises the COM port as COM3 and I have also checked this within Device Manager as well. As for the error message, it comes from the Firmware updater itself under the "Advanced Dialog" tab, I have attached a photo so you can see.
Postato : 18/01/2020 1:28 am
@knights
maybe ths could help:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/the-semaphore-timeout-period-has-expired/#post-128558
Postato : 18/01/2020 1:53 am
1 persone hanno apprezzato
Knights
(@knights)
@karl-herbert
Fixed, Thanks Karl, you're an absolute gun 😀, turned off bluetooth, restarted laptop and....... Hey Presto!!! Firmware Flash worked..
Thanks again to everyone that helped out..
Happy Printing.
Postato : 18/01/2020 5:32 am
@knights
fine, happy printing too 😀
Postato : 18/01/2020 12:49 pm
MCMakeIT
(@mcmakeit)
@karl-herbert
I wanted to flash to firmware 3.9.1 today and had the same problem/error. Bluetooth and WLAN deactivated and it worked! Thanks!
Anycubic I3 Mega, MK3s
Postato : 16/11/2020 3:01 pm
lemoineer
(@lemoineer)
This solution also worked for me, but I was getting a different error message...I'm using a Macbook Pro, and was getting a firmware fail message, but the log file was blank. Tried a different cord, USB port, reinstalled PrusaSlicer, redownloaded firmware update...nothing. Then turned off bluetooth and restarted computer, and voila!
Postato : 16/11/2020 7:04 pm
@jo-do
@eric_lemoine
I am glad that it worked out for you too 👍 .
Bluetooth is our enemy 😉 !
happy printing!
Postato : 16/11/2020 8:34 pm
