Firmware update causing problems
Bstei18
(@bstei18)
I've updated my Mk3S to firmware 3.9.3 using the latest Prusa Slicer. The update said it completed successfully but since then the printer has behaved erratically. All of my prints before this completed fine but after the update whenever I turn it on it says its recovering the last print. When I try to unload the filament and I press the knob after heating, it doesn't unload the filament but the carriage assembly goes to the top until I hit the X to stop it.
There were no power interruptions during flash, I have the printer on a UPS and run the software from a laptop. I've tried flashing an earlier firmware version that says it completed successfully, but the results are exactly the same.
Any help would be appreciated.
Best Answer by karl-herbert:
Posted by: @bstei18
I have also had this problem and it happened after a power failure. The solution was a factory reset and reflash the firmware.
good luck!
Publié : 19/03/2021 1:50 pm
RE: Firmware update causing problems
I’d get on the chat with Prusa support on their web site. Fastest way to get this resolved.
Publié : 19/03/2021 3:14 pm
Posted by: @bstei18
good luck!
Publié : 19/03/2021 4:37 pm
Bstei18
(@bstei18)
@karl-herbert
This was the way to go. After the reset, I loaded the new firmware, re-calibrated the printer and it's working fine now.
Thank You.
Publié : 20/03/2021 9:19 pm
Bstei18
(@bstei18)
@fuchsr
A factory reset turned out to be the best solution. Thank you for your suggest though, that would have been my next step.
Publié : 20/03/2021 9:20 pm
@bstei18
...is often the easiest and most effective way, even if you have to recalibrate.
happy printing 👍
Publié : 20/03/2021 10:19 pm
