Firmware update
vcrow2
(@vcrow2)
Firmware update
Hello, I have a PRUSA I3 MK3. By mistake I have loaded the firmware of the MK3S model into an MK3. I have tried to fix it by loading the MK3 firmware again but it tells me that I have loaded MK3 firmware on an MK3S printer. It is as if the MK3S firmware has changed the printer type. Can it be reversed? Thanks.
Napsal : 31/03/2020 7:35 pm
RE: Firmware update
Posted by: @vcrow2
Do a full factory reset and try it again.
https://help.prusa3d.com/en/article/factory-reset_2216
Napsal : 31/03/2020 8:36 pm
vcrow2
(@vcrow2)
RE: Firmware update
Hello, thanks for the answer. I have tried it but it keeps giving the message. 🙁
Napsal : 31/03/2020 9:57 pm
Jerry
(@jerry)
RE: Firmware update
Deleted all stored data?
Napsal : 02/04/2020 7:24 pm
RE: Firmware update
@vcrow2
Prusa MK3 bootloader is "read-only" that means that even if you upload improper firmware or make any other mistake, there is always a way to make things right. The best practice when uploading or flashing simply does not work is to follow the steps for a Factory reset of all data.
Here the link to the newest MK3 Firmware: https://cdn.prusa3d.com/downloads/firmware/prusa3d_fw_3_8_1_MK3.zip
If this does not work i would contact the Prusachat.
Napsal : 02/04/2020 7:51 pm
