Firmware Suggestion! Ability to resume print when "SD card removed" - faulty hardware 🙁
rw3iss
(@rw3iss)
Looks like my SD card reader has become faulty... constantly thinks the SD card is being removed... I will try and open it to adjust the pins a bit, but there should be some option to resume the print if the printer detects the SD card has (accidentally) been removed, similar to crash detection or power failure...
Posted : 26/01/2021 12:14 pm
RE: Firmware Suggestion! Ability to resume print when "SD card removed" - faulty hardware 🙁
Can you make the suggestion of prusa github?
Posted : 26/01/2021 9:42 pm
rw3iss
(@rw3iss)
Yes! Thank you.
Posted : 26/01/2021 10:00 pm
