Firmware Flash failed (from Slic3r), but printer show 3.7.1 on support screen
wlcina
(@wlcina)
I tried to flash and reflash my MK3, but all the time Slic3r reported that flash is failed, anyway, printer is working, and showing the latest firmware. Should I be worried?
Opublikowany : 17/05/2019 5:20 am
jsada.xyz
(@jsada-xyz)
RE: Firmware Flash failed (from Slic3r), but printer show 3.7.1 on support screen
The update has many processes and usually finish verifying the firmware.
It could be that the firmware was updated but the verification failed.
In your case I would try again.
Try to download the firmware again and update it with a different usb cable.
The flash process has the option to give extra information. Could you share this info if it continues failing?
Opublikowany : 17/05/2019 6:25 am
wlcina
(@wlcina)
Tried again, restarted PC, Printer, changed cable - it worked. Dont know where the issue was. 😀
Opublikowany : 17/05/2019 9:24 am
1 ludzie polubili
