Firmware error during print
Rick
 Rick
(@rick-11)
I have a MK3 that's suddenly fails during printing.  It's on the latest firmware.
Has anyone encountered this error before?
Octoprint detects the error and shows this message
This is what I see on the LCD when the printer stops
Postato : 09/02/2020 5:45 pm
RE: Firmware error during print
Posted by: @rickie-r
Did you send any lower case commands to the printer (m190 instead of M190 or g1 instead of G1)?
Postato : 12/02/2020 3:03 pm
Rick
 Rick
(@rick-11)
@karl-herbert
I didn't send any specific commands to the printer.  I created a file in Fusion360 and sliced with PrusaSlicer.
This was the 5th print of that file that failed with the screen corruption.
Postato : 01/03/2020 3:21 am
Rick
 Rick
(@rick-11)
I contacted support and they requested that I remove the PiZero and try again.
Multiple test prints all fail with "MINTEMP Fixed.  Please restart" errors.
Postato : 01/03/2020 3:22 am
thomas-hess
(@thomas-hess)
@rickie-r
Hello,
I have the same problem.
Printer always fail "Multiple test prints all fail with "MINTEMP Fixed. Please restart" errors."
Display shows " Bed Temp. O C°
Any solution about this problem by support?
Postato : 04/03/2020 5:01 pm
@thomas-hess
Mostly a broken thermistor/wire.
The topic has been discussed many times. Maybe you will find a solution here:
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/mintemp-error-4/
or here:
https://help.prusa3d.com/en/article/mintemp-and-mintemp-bed_2169
Postato : 04/03/2020 7:08 pm
thomas-hess
(@thomas-hess)
@karl-herbert
Thank you so much.
The bed termistor cable was broken.
I soldered a new one. High quality silicon cable !
Everything OK.
Postato : 05/03/2020 9:38 am
Rick
 Rick
(@rick-11)
@karl-herbert
Thanks for the links.  The thermistor eventually failed (0 degrees at all times).  I've ordered a replacement.
Postato : 05/03/2020 12:49 pm
@thomas-hess
Hi Thomas,
Flexible Silicone wire is probably the best solution, what gauge did you use?
Postato : 05/03/2020 2:01 pm
