RE: Firmware error during print
I have a MK3 that's suddenly fails during printing. It's on the latest firmware.
Has anyone encountered this error before?
Octoprint detects the error and shows this message
This is what I see on the LCD when the printer stops
Did you send any lower case commands to the printer (m190 instead of M190 or g1 instead of G1)?
@karl-herbert
I didn't send any specific commands to the printer. I created a file in Fusion360 and sliced with PrusaSlicer.
This was the 5th print of that file that failed with the screen corruption.
I contacted support and they requested that I remove the PiZero and try again.
Multiple test prints all fail with "MINTEMP Fixed. Please restart" errors.
@rickie-r
Hello,
I have the same problem.
Printer always fail "Multiple test prints all fail with "MINTEMP Fixed. Please restart" errors."
Display shows " Bed Temp. O C°
Any solution about this problem by support?
@thomas-hess
The topic has been discussed many times. Maybe you will find a solution here:
or here:
https://help.prusa3d.com/en/article/mintemp-and-mintemp-bed_2169
@karl-herbert
Thank you so much.
The bed termistor cable was broken.
I soldered a new one. High quality silicon cable !
Everything OK.
@karl-herbert
Thanks for the links. The thermistor eventually failed (0 degrees at all times). I've ordered a replacement.
@thomas-hess
Hi Thomas,
Flexible Silicone wire is probably the best solution, what gauge did you use?
