Firmware Crash When SD Card is Removed 3.12.1&3.12.2
TKS
 TKS
(@tks)
Hello. I'm currently facing a problem where the firmware crashes immediately upon removing the SD card.
I would like to know how others who have encountered a similar issue have dealt with it.
I received helpful advice through the help chat and attempted a factory reset, but the problem reoccurred.
The SD card has been formatted once.I've tried firmware versions 3.12.2 and 3.12.1, but the issue persists in both.
Opublikowany : 30/04/2023 2:04 am
Juts
 Juts
(@juts)
RE: Firmware Crash When SD Card is Removed 3.12.1&3.12.2
Same issue. I just let it reboot.
Likely a bug with the new FW.
Opublikowany : 02/05/2023 1:26 am
1 ludzie polubili
TKS
 TKS
(@tks)
Thank you for your reply.
Are there any reports of similar issues occurring with the new firmware? Is the development team aware of this problem?
Opublikowany : 02/05/2023 11:02 pm
Torben Nikolajsen
(@torben-nikolajsen)
When i updated my Prusa MK3s+ today with the 3.12.2
I did it with the Prisa slicer.
It reboots again and again.
The Prusa menus never shows. Only the firmware nummer and no more.
Opublikowany : 07/05/2023 8:27 pm
There are a plethora of issues with the firmware crashing on the 3.12 versions.  The github for the Mk3 firmware is located here https://github.com/prusa3d/Prusa-Firmware/issues?q=is%3Aissue+is%3Aopen+sort%3Aupdated-desc
Crashing in the middle of prints, crashing at specific ambient temperatures, several MMU crashes etc.  From what I've seen of the issues there anyone running 3.12 is just asking for problems.  You couldn't pay me to run it in the state its currently in.
Opublikowany : 07/05/2023 10:28 pm
Juts
 Juts
(@juts)
Posted by: @neophyl
I've only had it crash after pulling the SD once, and never any other time. I've had it printing actively a solid  48-72hrs across 7 or 8 prints without issue.
Opublikowany : 07/05/2023 11:28 pm
Hello
(@hello)
Posted by: @neophyl
Same I would never ever go to current firmware unless all bugs get fixed 3.11 work fine why go 3.12 and get issues I recommend going to 3.11
Opublikowany : 08/05/2023 9:05 am
