Firmware and Odd Sized Nozzles
pimogo
(@pimogo)
So have a whole assortment of nozzles i want to begin to experiment with, but the firmware for an MK3s only lists the common 4 (i.e. .25, .4, .6, .8), what do i use if my nozzle does not correspond. for example i intend to use a .3 nozzle. Should i simply select the .25 in the firmware? Naturally i'll have to configure the width and such in the slicer while creating a custom preset, but confused about what to enter in the printer firmware itself.. Is it even important? What does it do that the slicer does not account for?
Best Answer by bobstro:
Posted by: @pimogo
[...] Naturally i'll have to configure the width and such in the slicer while creating a custom preset, but confused about what to enter in the printer firmware itself.. Is it even important? What does it do that the slicer does not account for?
The alert on the printer is just a wwrning. Setting a nozzle size in the printer menu doesn't change any print parameters. I find the warnings annoying since I use a range of nozzle sizes. You can:
  1. Remove or disable the nozzle check line from your start gcode in a custom print profile.
  2. Disable the check in the printer menu.
Ce sujet a été modifié il y a 5 years par pimogo
Publié : 28/01/2021 12:43 am
RE: Firmware and Odd Sized Nozzles
Posted by: @pimogo
Publié : 28/01/2021 3:08 am
pimogo
(@pimogo)
@bobstro
Thanks @bobstro. I knew you'd have the answer. Also thanks for the wonderful material you've made available on your website. I've learned a great deal from it!
Publié : 28/01/2021 3:56 am
Glad it's helpful. Nozzles really expand your range of options.
Publié : 28/01/2021 5:47 am
1 personnes ont aimé
