Firmware and MacBook M1
I have change my MacBook for the new M1. I have purchased also an adapter to USB C to connect the printer into my Mac.
I have also installed the latest version of the Prusa Slicer.
I have try to flash my printer, but the software does not seem to see the printer.
does everything is fully compatible with the new Mac hardware? Or it will better to use a USB hub?
RE: Firmware and MacBook M1
I have try to flash my printer, but the software does not seem to see the printer.does everything is fully compatible with the new Mac hardware? Or it will better to use a USB hub?
Others has reported this problem and no there is not work aroudn at this time.
@cwbullet
Thank you.
I have a workaround, bring my printer near my PC, or better, print my laptop from the job.
