#Firmware 3.3.1 for i3 MK3
new release yesterday:
https://www.prusa3d.com/drivers/
CHANGES IN 3.3.1
per git
Detailed description of changes:
There was missing OK after G28 (auto home) gcode execution (issue #924) which could cause communication timeouts and also undesired mesh bed leveling was run in the end of temperature calibration. Both was caused by bug in G28 gcode. It has been fixed.
Load filament sequence now contains movement in Z axis if current Z coordinate is lower then 20mm when loading filament starts. This will ensure that there is always enough space for cleaning the nozzle.
- Splash screen fix
- Factory reset -> Shipping prep. enables filament sensor
Publié : 18/07/2018 7:27 pm
