Firmware 3.2.0-RC1 for Original Prusa i3 MK3
Stránka 1 / 3
marek.c3
(@marek-c3)
UPDATE: there is a newer version available! More here https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f64
Hi there,
new version of firmware 3.2.0-RC1 for MK3 and MK2.5 is out! Note this is a test build for advanced users 😉
What is new:
MK3:
- linear advance
- new xyz calibration
- filament sensor function improved
- safety timer
- G-codes for setting temperature correction
- extruder linearity correction
- stealth mode for Z axis
MK2.5:
- linear advance
- safety timer
Supported printers:
This firmware supports Original Prusa i3 MK3 and MK2.5
Download link and description:
https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.2.0-RC1
Firmware flashing guide:
http://manual.prusa3d.com/Guide/Upgrading+firmware+v1.2/66?lang=en
Please report any bug here:
https://github.com/prusa3d/Prusa-Firmware/issues
As always, we wish you happy printing and look forward to your feedback!
Napsal : 13/04/2018 8:49 pm
jake.m3
(@jake-m3)
Re: Firmware 3.2.0-RC1 for Original Prusa i3 MK3 and MK2.5
XZY Cal is failing, no issues before.
Napsal : 13/04/2018 9:53 pm
Olef
 Olef
(@olef)
Working fine here. Selftest + xyzcal + 1st layer cal all flawless. Test print perfect.
Napsal : 14/04/2018 12:36 am
Benpascode57
(@benpascode57)
Fonctionne bien ici. Selftest + xyzcal + cal de la 1ère couche tous impeccables. Test d'impression parfait. 😀
Napsal : 14/04/2018 1:03 am
john.v11
(@john-v11)
Try checking your PINDA height using the zip tie method.
Napsal : 14/04/2018 6:38 am
sylvie.v
(@sylvie-v)
i confirm the xyz calibration doesn't work with my mk3
Napsal : 14/04/2018 11:42 am
stahlfabrik
(@stahlfabrik)
I get a warning that my printer board has changed and that old settings have been restored. What has happened here? I did a factory reset and the message reappears after a PID tune...
I cannot reproduce the exact warning text in the moment.
Napsal : 14/04/2018 4:25 pm
vaxxi
(@vaxxi)
Got the same message as well, it's a message about motherboard having changed and settings being reset.
First XYZ calibration failed miserably, with a "calibration point not found" error and some steppers loudly grinding. LCD was left in a "strange" state as well. Next XYZ calibration executed right after went fine. The 'motherboard message did not appear for me after a reboot.
Napsal : 14/04/2018 4:48 pm
FlyAttack
(@flyattack)
XYZ calibration is failing for me. Nozzle crashes on the front right. New kit builder. With the "grey" pinda probe.
Napsal : 14/04/2018 7:20 pm
travis.h4
(@travis-h4)
So is it 3.1.4 RC1 or 3.2.0 RC1? I'm confused
Napsal : 14/04/2018 11:39 pm
Mike
 Mike
(@mike-8)
XYZ calibration gets realy close to the bed.
Napsal : 15/04/2018 12:02 am
vincenzo.a
(@vincenzo-a)
Tested on a MK3
- As said before strange alert message about PID and setting reset and Mainboard change.
- XYZ calibration OK but result skew bigger than before (0.05 vs. previous 0.00), faster as advised (>10min) and yes, very close to the bed.
- PID calibration OK (in the previous release sometimes failed)
- Temp calibration OK but is necessary starting with cold (ambient) PINDA. If the procedure start with an already warm PINDA, fails or in another case takes forever. Please let PINDA cool down before starting the calibration. ATTENTION if the calibration starts without the plate on the bed, the nozzle crashes on the bed! It is necessary starting the the procedure with the plate installed and remove it only when requested (Please FIX!).
Napsal : 15/04/2018 12:05 am
Tiago
(@tiago)
Same here, but i can't get it to cal xyz.
My previous good Live Z value was -0.740
Napsal : 15/04/2018 3:37 am
Terb
 Terb
(@terb)
My xyz cal got super close to the bed. I thought it would rip through the paper (it didn’t). My bed looks unscathed. I haven’t tried a print yet. Has everyone else’s been like this?
Napsal : 15/04/2018 6:38 am
Masher
(@masher)
MK2S to MK3 upgrade. XYZ calibration fails with 3.2.0-RC1 for me. Most times it would fail on the third point, but occasionally would fail on first point. If I did a factory reset the first point seemed to always work first try, but it would never get past the third point.
Used the zip tie method when assembling, but also lowered pinda a quarter turn to no avail (after the failures).
Reverted to previous version and XYZ calibration worked without issue.
Napsal : 15/04/2018 8:53 am
Pintie
(@pintie)
xyz fails ... no problems before
tried couple of times.
best was to complete to point 4, but then "couldn't find calibration point"....
Napsal : 15/04/2018 10:06 am
Crunch
(@crunch)
3.2.0 RC-1 the nozzle crashes the bed when calibrating xyz, calibrating z, auto home and calibrating PINDA temp
also the bed and the PINDA does not center on the circles it is shifted to the left and back of center
The Gcode M860 and M861 does not seem to work get error unknown code
The Latest Firmware can be found here https://github.com/prusa3d/Prusa-Firmware/releases
Open Firmware Issues https://github.com/prusa3d/Prusa-Firmware/issues
Napsal : 15/04/2018 7:02 pm
Szafran
(@szafran)
How about print quality with the FW ? Does LA work ?
Best regards... Szafran... MK3S + MMU2S + OctoPrint on DELL 3020m
Napsal : 15/04/2018 7:29 pm
stahlfabrik
(@stahlfabrik)
I also have had the nozzle crash - but just to be sure: you have installed the MK3 version on your machine? Not the MK2.5 version?
Because I can run the M861 gcode - at least:-)
Regarding the nozzle crashes: it is like the MK3 has forgotten where its calibration points are. Maybe it thinks it is a MK2, which has a different heatbed design.
Napsal : 16/04/2018 2:16 pm
RH_Dreambox
(@rh_dreambox)
Firmware 3.2.0-RC1
The printouts are offset 5 mm backward on the Y axis, which is also confirmed by Edward here:
https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/9-days-without-commit-on-github-i-feel-something-b-t15124-s40.html
Napsal : 16/04/2018 5:42 pm
Stránka 1 / 3
