Firmware 3.9.0-3421 not sorting G code by time.
Chuck B
(@chuck-b)
Firmware 3.9.0-3421 sorts by alphabetic, but not by time required to make the part.
Chuck
Veröffentlicht : 29/08/2020 3:36 am
RE: Firmware 3.9.0-3421 not sorting G code by time.
It was my understanding that sort by time was the timestamp that the gcode was created or modified, not by how much time it takes to print.  I think you also have to set how the files are sorted from the lcd menu system as an option.
Veröffentlicht : 29/08/2020 7:45 am
Chuck B
(@chuck-b)
I am sure you are right, it would be nice to have an option to sort by build time.
I do not leave my printer running when I am not here or I am sleeping.
I have to scroll thru the list to search for one that will fit in the time I want the printer to run.
I hope they see this and can add the option.
thanks
chuck
Veröffentlicht : 29/08/2020 3:14 pm
3Delight
(@3delight)
Moderator Moderator
It's unlikely anyone from Prusa will see it on here, I suggest you make a Feature Request over on the Official GitHub Issues here:
https://github.com/prusa3d/Prusa-Firmware/issues
Veröffentlicht : 29/08/2020 3:18 pm
Chuck B
(@chuck-b)
Thanks, I am new to 3D printing and thank everyone for the help!
chuck
Veröffentlicht : 29/08/2020 3:45 pm
You can change the format that the files are named as by altering the output options in a print profile. If you move the print time placeholder to the start of the sequence , then if sorted alphanumerically then the files would be in print time order. You don’t need any change to the software to do that.
Veröffentlicht : 29/08/2020 3:49 pm
Chuck B
(@chuck-b)
Thank you for the info, I will look at that. I had thought of renaming the files and putting the time at the front but did not know how it would affect things. Does this have to be done in slicer or can I just rename the files?
Diese r Beitrag wurde geändert Vor 6 years von Chuck B
Veröffentlicht : 29/08/2020 4:02 pm
Chuck B
(@chuck-b)
Although being able to switch between Alphabetic and build time using the lcd would be much better for me.
I still would like to be able to quickly sort by name of the part. I have asked this on the other site that was listed above.
Veröffentlicht : 29/08/2020 4:19 pm
You can rename the files however you like, manually or otherwise.
Personally though I would just modify and save an updated print profile in slicer.
Under - Print Settings> Output Options- you normally have something like
{input_filename_base}_{layer_height}mm_{filament_type[0]}_{printer_model}_{print_time}.gcode
If you change that to
{print_time}_{input_filename_base}_{layer_height}mm_{filament_type[0]}_{printer_model}.gcode
then the gcode files exported when using that print profile will have the print time at the start.
So any system that is sorting files based on alphanumerics should then list them in that order.
Veröffentlicht : 29/08/2020 5:18 pm
