Firmware 3.14 problem on i3MKS
Manuel
(@manuel-4)
Mitglied
Hi , after upgrading to Firmaware 3.14  ( Prusa i3 MKS  model) I get the following situation:
1.- 'Load Filament' option disappeared from  LCD screen menu
2.- Octoprint cannot find printer ( no serial port detected )
Back to 3.13, all works fine.
File I used : prusa3d_fw_MK3S_MK3S+_3_13_3_7094.hex
Anyone with similar problem?
Veröffentlicht : 14/07/2024 9:02 am
CMR
 CMR
(@cmr)
Yes, same issue (missing Load Filament) on my i3 MK3S+. Firmware MK3S_MK3S+_FW_3.14.0_MULTILANG.hex.
Diese r Beitrag wurde geändert Vor 2 years von CMR
Veröffentlicht : 17/07/2024 6:43 pm
Dave
 Dave
(@dave-20)
Mitglied
I had loaded the MK3S_MK3S+_FW_3.14.0_MULTILANG.hex firmware late last night after I finished printing something.
This morning it wouldn't Load Filament correctly.
I deleted last nights downloaded file and went back to Prusa and downloaded the firmware again and reloaded it on my MK3S+.
The filament now loads correctly.
Diese r Beitrag wurde geändert Vor 2 years von Dave
Veröffentlicht : 18/07/2024 3:08 pm
fwj
 fwj
(@fwj)
Mitglied
RE: Firmware 3.14 problem on i3MKS
I got the same issue (missing Load filament) on my MK3S after loading MK3S_MK3S+_FW_3.14.0_MULTILANG.hex
I reloaded prusa3d_fw_MK3S_MK3S+_3_12_1_5686.hex and "Load filament" came back.
I have no attachments.  I print off the SD card.
Veröffentlicht : 19/07/2024 5:44 am
Amos Bustan
(@amos-bustan)
Mitglied
me too.
have the same problem
Posted by: @manuel-7
Veröffentlicht : 03/09/2024 3:36 pm
Amos Bustan
(@amos-bustan)
Mitglied
I have the same problem.
drewster
(@drewster)
https://forum.prusa3d.com/forum/original-prusa-i3-mk3s-mk3-hardware-firmware-and-software-help/fil-loading-issue-fw-3-14-0/
Veröffentlicht : 18/10/2024 8:21 pm
joemiro
(@joemiro)
Same problem here. We have to go into the settings and manually move the extruder gears to load filament now.
Veröffentlicht : 21/10/2024 11:33 am
CMR
 CMR
(@cmr)
So the real question becomes, is Prusa going to address this and if so, when? This has been an open/ongoing issue since at least 3 months.
Veröffentlicht : 29/10/2024 7:22 pm
Eli
 Eli
(@eli-6)
Mitglied
I haven't had any issues with loading filament, I use an MK3s+, however, I've had quite a bit of issues with the hotend temperature.
Veröffentlicht : 30/10/2024 5:39 pm
Chris Barnes
(@chris-barnes)
Having the same problem here
Veröffentlicht : 07/02/2025 6:58 pm
