[Rozwiązany] File Incomplete - Continue Anyways?
QuinG
(@quing)
Hey everyone,
For some reason every time I try and and slice an object now and put it on the printer I keep getting this error message reading "File Incomplete- Continue anyways?"
I've tried multiple slicers now but just keep getting the same error. I've also tried multiple objects off thingverse with no luck. There should be nothing wrong with the gcode so I don't know what is wrong. I've even tried several different SD cards.
Please Help! 🙂
Opublikowany : 04/06/2021 1:38 am
QuinG
(@quing)
RE: File Incomplete - Continue Anyways?
I just tried that same gcode on another printer and it works...
Opublikowany : 04/06/2021 2:17 am
QuinG
(@quing)
*Update - I figured out that all I had to do was reformat my SD card
Opublikowany : 04/06/2021 3:40 am
Xanthe
(@xanthe)
When I had this problem it was due to a character in the filename that the printer's OS didn't recognise.
The particular character concerned was ° (unicode 00B0, the degree symbol).
Opublikowany : 07/06/2021 3:53 pm
