Filament will not load
motocoder
(@motocoder)
I was trying to print a single-walled cube, to do some extrusion multiplier calculations on Prusa PETG, when I started receiving print fan errors. During troubleshooting of this, I unloaded the filament. When I went to load it in again, it will not load. I can feel the printer start to pull the filament in, but then it stops.
(EDIT) I removed the extruder from the printer. It looks like the problem is that the filament broke off just where it enters the tube below the Bondtech gears. I am not sure what the best way is to repair this.
Postato : 28/04/2018 5:32 am
Re: Filament will not load
can you heat the extruder then grip the end of the filament with long nose pliers, then pull it out
if you can't pull it out, then try pushing it in, with the end of another length of filament
Postato : 28/04/2018 11:05 am
motocoder
(@motocoder)
Thanks, Joan. I will give it a try once I have everything re-assembled.
Postato : 28/04/2018 5:36 pm
Pete
 Pete
(@pete)
Wish you luck.
Had something similar last week and wasn't able to pull the filament out nor push it through with another piece of filament. Didn't try with a wire as suggested in the knowledge base as last resort. Feared I might damage the extruder or the hotend.
Finally I removed the hotend. The culprit was a blob of PLA at the very end of the teflon tube just before the heatbreak. Unfortunately I've had damaged the teflon tube during my first tries to push the filament down. Luckily had a spare piece laying around which I've cut to length and installed.
Reassembled the printhead and everything was fine again.
Postato : 28/04/2018 7:27 pm
motocoder
(@motocoder)
Hi Joan -
I just wanted to thank you for the advice. After I reassembled everything, I heated it up as you suggested, and then pushed upwards from below by inserting a nozzle cleaning needle into the nozzle end. The filament popped up and I was able to extract it exactly as you suggested.
Many Thanks,
Matt
Postato : 13/05/2018 6:59 am
Thank you Matthew,
most issues have been experiences by someone on the forum already, sharing our experiences can help resolve issues more quickly.
Postato : 13/05/2018 8:14 am
