Filament stuck and broken under gears
trainspotta
(@trainspotta)
So my MK3S stopped moving Filament.
I followed the clocked Nozzle tutorial. The Needle goes way up, like 3cm at least.
Then I wanted to remove the filament. It was worn down. I could not load it. Then I opened the "gearbox" and I can see a little bit of filament sticking out. What do I do now? Do I need new heatbreak? The printer is not even a week old?
Napsal : 10/11/2020 1:20 pm
trainspotta
(@trainspotta)
RE: Filament stuck and broken under gears
Ok I found a video and the guy said to push it further down. But this down not work. The nozzle seems to be free. So clogged hotend?
Napsal : 10/11/2020 2:05 pm
Fred
 Fred
(@fred-2)
I would recommend you following the guide below, as you don't want to damage the Hotend PTFE Tubing or the extruder gears.
There's also a more advanced technique called cold pull but make sure you follow carefully the instructions below as again you don't want to damage any of the parts I mention before.
Hotend PTFE Tubing
This post was modified před 5 years 2 times by Fred
Napsal : 11/11/2020 2:28 pm
