Filament Sensot not working
Polysulfide
(@polysulfide)
This seems to coincide with upgrading to FW 3.14 but could just be a coincidence since I haven't used the printer in a while.
When autoloading filament the filament isn't detected and the extruder doesn't engage.
This isn't a huge deal, I can manually load filament.
- Have no "unload" ability because it doesn't know its loaded
- Printing works fine
- Can't perform 1st layer calibration which is kind of essential for new filaments.
The wires are all good and getting 5v from the board.
I can't find the replacement part in the store.  It says "PRUSA Laser sensor" rev 0.2e
It has 4 pins.  It looks like possibly the IR sensor might fit physically but it only has 3 pins.
Are there any known issues with the FW that could cause this?  If not, how can I get a replacement sensor?
This topic was modified před 5 months by Polysulfide
Napsal : 03/12/2025 8:18 pm
1 lidem se líbí
Bass.Boi
(@bass-boi)
I have exactly the same problem ony MK2.5S.
Everything was working prior the update, i did print the same day and it was fine.
Updated from 3.14.0 to 3.14.1 and it looks like the sensor is not detected anymore.
I will probably downgrade.
Don't wanna buy new printer just yet as mine is working fine.
This post was modified před 5 months by Bass.Boi
Napsal : 17/12/2025 8:12 am
1 lidem se líbí
lkp
 lkp
(@lkp)
RE: Filament Sensor not working
I had the same issue with the 3.14 with the filament sensor not being detected. I have an MK3
Napsal : 07/01/2026 10:58 pm
1 lidem se líbí
Polysulfide
(@polysulfide)
RE: Filament Sensot not working
No answer from Prusa on the community or support for a year!
I bought an AnyCubic.  I'm so freaking happy.  Prusa was my first and I didn't know what I was missing.  I can't believe I keep upgrading that POS year after year.
They lost a lifetime fan and everyone I can influence over an ounce of communication.
Napsal : 17/03/2026 5:03 pm
tlocke01
(@tlocke01)
Does anyone have a solution for this? I just updated to 3.14.1 and now I can no longer autoload filament and worse I can't turn off the sensor in settings so I can't manually load filament either.
Napsal : 08/04/2026 10:14 pm
