Filament sensor stucks
Hello there! I bought MK3S kit. I assembled everything. Everything was working as it should be. It took the filament automatically when I first started the printer. Then I realized that the IR filament sensor always gives the value 1. Auto loading dont working. IR sensor does not give the value 0 when there is no filament.
I tried the solution on this page. I cleaned the printed part. But still the problem has not been solved. It works if I don't assemble the extruder motor. When I reassemble, the IR sensor is stuck and returns only 1 value.
What should I do?
Publié : 27/06/2020 11:33 pm
