Filament Sensor - Quick Fix
kaje
 kaje
(@kaje)
My filament sensor suddenly stopped working (filament would not auto-load), so I took a look at the Prusa Knowledge Base for a solution. There was a good write-p there, but it involved extensive dismantling of the print head assembly.  It also mentioned that debris in the sensor can be one cause of the problem.
I decided to try a less invasive approach first: First I unloaded the filament and let then machine cool down. Then I removed the cover over the filament sensor, and then removed the screw holding the sensor in place. Without disconnecting the sensor I partially removed it. I next removed the screw holding the extruder idler door. Using a can of compressed air, I blew air into the sensor opening on top, and then into the opening of the idler mechanism. I repeated this twice, and noticed a small bit of plastic debris blow out.
I reassembled everything and tested the sensor - problem solved!  The whole procedure took about 5 minutes. Definitely worth trying first if you have filament sensor problems.
Postato : 23/05/2021 12:32 am
Utenti
RE: Filament Sensor - Quick Fix
Disable the filament sensor.
Postato : 23/05/2021 12:50 am
