Filament sensor [N/A] after v3.12.2-5713 firmware upgrade, but changes state in Support/Sensor_Info
Wnrsm
(@wnrsm)
i3 MK3S here - I upgraded the firmware to v3.12.2-5713 and the filament sensor stopped working.
In "Configuration" the "Fil. sensor" option is [N/A] and selecting it gives a message about it not being detected.
I'm certain that the wiring and sensor are operational because I see the "Fil. sensor" change between "0" and "1" in teh Support/Sensor_Info.
Is there any way to save my settings before performing a factory reset?  It has been a while and I'm not sure I remember what I have customized.  It would be great to keep the print surface profiles and z-distance.
Opublikowany : 16/04/2023 2:55 am
