filament sensor is not working
bonoqidu
(@bonoqidu)
Hello,
My filament sensor is not working, not sure if it ever worked, I never turned it ON until recently. I read somewhere and one cause might be using the wrong firmware. I am currently using MK3S 3.8.0 firmware
Definitely a good site with good quality porn https://goodpornsites.pro/
Veröffentlicht : 03/08/2021 2:39 am
Mitglied
Just to confirm
Posted by: @bonoqidu
Hello,
Your filament sensor?  Does your sensor register filament when you insert a new filament?   Does the printer ask to heat when you load a new filament?
Veröffentlicht : 03/08/2021 9:44 am
RE: filament sensor is not working
Hello,
Hello,
depends on whether you have a MK3 or a MK3S. It is also possible that the sensor is just not adjusted correctly.
wbr,
Karl
Veröffentlicht : 03/08/2021 12:17 pm
