Filament runout sensor default on
Hi there,
I have a Prusa MK3 with firmware 3.9.2 and 'old' filament sensor. The sensor itself works fine, if I enable this and autoload filament it works fine.
The challenge is that the setting is not saved (and set default to [off]) When I print a big part (via octoprint) and run out of filament it fails because I didn't remember to enable this in the menu. As far I can see there is no option to save this default.
I found the gcode M412 as gcode command, but it seems the prusa don't respond to this code ( https://marlinfw.org/docs/gcode/M412.html)
Is there a way to turn it default on? (also after turning the printer off)
Napsal : 05/03/2021 4:36 pm
