Filament Is Ejecting After Prints
Brandon
(@brandon-8)
After a print is complete it is ejecting the filament. This is something that is happening that used to not happen. This is a problem because each time it ejects the filament is getting stuck, maybe the filament is still hot before ejecting and it make a blob and gets stuck in the gears. I updated my firmware recently which may have caused this? I do see a M702 at the end of the gcode.
Best Answer by FoxRun3D:
You can check the end gcode in your printer settings in Prusaslicer. I can't recall for sure but I think you need to be in advanced or expert mode in Prusaslicer to see it.
Napsal : 13/01/2024 7:12 pm
RE: Filament Is Ejecting After Prints
Napsal : 13/01/2024 8:48 pm
ssill2
(@ssill2)
when you updated firmware, did you also update the version of the slicer?   I don't have an mk3 anymore(I upgrade my two units to MK4),  but I'm not sure I recall it ever ejecting filament after my print.  The MK4s definitely don't.  Check what slicer version you're using and see if your project is pointing at the latest version of the printer profile.  As @fuchsr said,  you might have to be in expert mode to see the gcode
Napsal : 13/01/2024 8:55 pm
Brandon
(@brandon-8)
Thanks folks that was it. I needed to be in expert mode before I could view the gcode. I removed the M702 and that did it for me.
Napsal : 13/01/2024 9:24 pm
