Filament color change
Sandi
(@sandi)
Recently (the last 3 prints) I have been getting the print stopping and the printer asking for a filament change. I have not programmed a filament change, it is doing it on its own.  Any reason why?  I have a fairly large print and it's been annoying that it keeps stopping for a filament color change when there is not one.  Thanks in advance.
Postato : 20/08/2019 1:29 pm
Greg
 Greg
(@greg-9)
RE: Filament color change
Did you double check that you did not accidentally add a color change in prusaslicer (the slider on the right after you slice the file and look at the layer view)?  I've done that once before is why I ask.
Postato : 20/08/2019 2:09 pm
Sandi
(@sandi)
Yes, I did. I specifically did because the previous print did the same thing to me. That's why I'm confused. But appreciate the answer.
Postato : 20/08/2019 2:17 pm
I'm guessing you have a MK3s, the filament sensor is very finicky and can register as no filament, that leads to a filament change process.  I'd be double checking that part of the build to make sure its reliable.  Either that are turning it off.
Postato : 20/08/2019 2:58 pm
1 persone hanno apprezzato
Sandi
(@sandi)
Sorry I didn't post that. It's an MK3.
Postato : 20/08/2019 4:01 pm
Posted by: mizzle54
If it's an OG Mk3 (not a Mk3s), try cleaning out the filament sensor. Mine had degraded badly to the point that I disabled it after a few months. I finally opened it up and (carefully) cleaned the sensor, and have made a point of blasting it out regularly. It is now very reliable, and only malfunctions with a few specific filaments. I prefer the old sensor arrangement and have not upgraded to Mk3s parts.
Postato : 20/08/2019 5:24 pm
What Bob said 🙂  I went a bit more extreme and printed off the butterworth extruder mod that uses a small bearing as an interface between the Mk3 sensor and the filament and now it works perfectly, even with transparent filament.  I thinks its way better than the new MK3s sensor.
Postato : 20/08/2019 5:51 pm
After my MK3 sensor proved unreliable on any color lighter than dark gray I disabled it.  High sheen filaments are a problem, light colors are a problem, translucent colors are a problem, and all because many filaments are translucent to the laser color used.
The sensor is actually a great idea, just too sensitive to some very basic filament characteristics.  When I was trying to use it, the pauses and halts were annoying. At first I just flagged the filament spool and planned end of spool manual changes during daylight hours. But after a while I just went with that routine for everything.
Postato : 21/08/2019 7:18 am
Texy
 Texy
(@texy)
Posted by: mizzle54
Upload as an attachment one of the gcode  files.....
Texy
Postato : 22/08/2019 3:18 pm
Sandi
(@sandi)
I will when I get back, going to be out of town for 12 days.
Postato : 22/08/2019 6:50 pm
