Filament color change extrude length not enough
Dutchy
(@dutchy)
i changed a few times now and the extruded amount isn't enough so each time I have to enter NO and extrude again.
So I think thee's filament piling up in the nozzle, this could also be causing inconsistent extrusion if this is the cause, Or is this normal due the unload script? If so then I think the LOAD amount should be a cm more.
Thanks,
Posted : 27/10/2018 2:12 pm
