filament change
I'm trying to write some gcode Commands that will allow me to do filament change.
I'm fairly new to the process, but as I understand it the most significant codes are 701 and 702. specifically, I am sending "M109 R255" and "M702" in order to heat the toolhead, followed by unload. the MK3 isn't responding to either the unload or load. It does however respond to M600 in order to pause to change filaments but that's not exactly what I want to do. 701 and 702 are listed in the supported G codes for the MK3. Is this a bug?
--Scott
Respondido : 24/04/2018 5:46 pm
Re: filament change
use color print to insert changes by layer. and if you do you will see the commands.
included in the prusacontrol software or https://www.prusaprinters.org/color-print/
Respondido : 25/04/2018 8:30 am
