Filament bleeding out of nozzle when heating
Pepijn
(@pepijn)
My prusa MK3S+ 'bleeds' filament when heating up. I replaced the hotend, thermistor and nozzle. I did a factory reset, software update and PID calibration, but the problem persists. When stopping a print, for instance, the filament keeps running out of the nozzle for about 10 seconds. When no extrusion is taking place.
What could be the reason for this ?
Posted : 19/09/2025 12:27 pm
How are you drying your filament?
Posted : 19/09/2025 6:08 pm
Pepijn
(@pepijn)
Thank you for replying. It is not about the filamet beeing wet. I have more 3D printers and if I try the same filament all is well.
This post was modified 5 months ago by Pepijn
Posted : 19/09/2025 6:16 pm
Tim
 Tim
(@tim-21)
For whatever reason my Core One leaves a 2 inch trail of filament dangling after a print, too.  I think its a combination of things to do with how the printer parks the filament: ramming then pulls it out of the nozzle which allows air into the chamber that then heats and forces whatever melt is in the nozzle CHT/HF orifices to feed downward with gravity. A SWAG, and leaves other questions, but it sort of explains why. It does it with several filament types, PLA, PETG, PC-CF, even fresh from the bag Prusament PLA did it. And all leave the same two inch dangle.
But wait - you are using a Mk3, sans Nextruder? Then nozzle is too hot or filament is damp. About the only things that will cause it.
Posted : 19/09/2025 6:25 pm
Pepijn
(@pepijn)
RE: Filament bleeding out of nozzle when heating
Thank you Tim, for taking the time to react on my post. I tried brand new filament from the box, not wet and the same thing happens. If I extrude a bit, and the extrusion motor stops, it keeps seeping out for more than 10 seconds. I changed the hotend (pla) temperature to 190 c. and still the same thing happens.
I cant wrap my head around it. Tried so much and still the same thing happens.
Posted : 20/09/2025 8:11 am
New does not necessarily mean dry - this really is a typical symptom of moist filament.
Posted : 20/09/2025 4:19 pm
Rob Norris
(@rob-norris)
They all do it.
Posted : 24/09/2025 6:50 pm
