Feature suggestion - beep when preheating has reached desired temperatures
Rob Latour
(@rob-latour)
Not sure where to make a feature suggestion, but I'll make it here and hope for the best 🙂
On the printer's control panel there is a feature to preheat (the bed and nozzle).  It would be nice if when the preheating has reached the temperatures required that the printer beeps (much like it does when it is ready for you to unload the filament).
Thanks.
Postato : 09/12/2022 10:52 pm
RE: Feature suggestion - beep when preheating has reached desired temperatures
This is a user to user forum. Bug reports and feature requests need to be made at the appropriate GitHub. There are ones for PRUSA slicer, the mk3, mini etc.
https://github.com/prusa3d
However you could just create some gcode that preheats with beeps. Then from the menu select print from sd and select the preheat gcode. No need to change any software, just a slight change to your personal workflow.
Postato : 09/12/2022 11:11 pm
Rob Latour
(@rob-latour)
Thanks
Postato : 10/12/2022 2:38 am
economicspolecats
(@economicspolecats)
Thank you for this clarification.
Postato : 13/12/2022 3:22 pm
