Fault wires on power input assembly
I am adding an enclosure and in the process of moving the power supply on my MK3, I accidentally broke of the black and white wires that are soldered to the small PC board the the 110vac power cord connects to, labeled "fault". My question is that while I know which two pads the wires attach, I do not know which wire goes to which pad. The two pads are at the corner of the PC board. Which wire attaches to the corner pad and which attached to the adjacent pad farther away from the corner?
Thank You
Terry Veldhuizen
Postato : 17/02/2020 5:39 am
