Fan Error every 30-45 minutes
Just got my 3S+ back up and running after a couple of years where I wasn't using it. Everything is great, except that I'm getting fan errors about every 30-45 minutes during longer prints. I can immediately resume without issue, and it will work fine for another 30-45 minutes until another fan error occurs.
Having read the fan replacement guide, I'm eager to try other remedies before I dive into that process.
Opublikowany : 28/07/2024 6:11 pm
First clean the fans (a stiff artist's painrbrush works well) and make sure there are no hairs or threads of stringing tangling the hub.
Most of the fans have a sticker sealing the hub on the inside - peel this back, put *one* drop of light machine oil into the hub/bearing and reseal the sticker.
Any better?
Opublikowany : 29/07/2024 12:07 am
1 ludzie polubili
