Fan error
I’ve recently been printing and after a few minutes into every print, the printer stops and gives a fan error message. This is specifically targeted at the print fan. In fact, when it prints for the first few minutes, there are no issues and all the fans are spinning. For the past few days, I’ve just turned off the sensor for the fans and everything prints fine. I have prusa i3 mk3s and prusament pla 1.75. I still want to have the sensor on just in case but I hate that it stops in the middle of all prints. What do I do?
Opublikowany : 09/05/2019 12:35 am
RE: Fan error
The yellow sense wire is probably damaged or broken. If you manually turn on the print fan, what does it read under the support menu for an RPM value?
Opublikowany : 09/05/2019 1:04 am
