Failure to load filament.
Hello, since a few days I have a Prusa MK3S with the MMU2S accessory, I have installed the Firmware 3.7.2 (1.0.5) in which would be integrated everything for MMU2S. I have done the calibration process and everything works correctly (also extrude to adjust the layer thickness), until the moment I select an object to print. The printer performs the self-leveling process and then when I should start printing it fails me with the filament, tells me to remove it, and reload it. I do it but the result is always the same.
Why is this failure? in the accessory for multifilament I have only loaded one filament in position 1.
Thank you in advance.
Translated with www.DeepL.com/Translator
Veröffentlicht : 05/08/2019 6:36 pm
