Fails self test and won't calibrate - says it can't find point.
Camel
(@camel-2)
Due to personal issues I haven't used my printer almost a year. (i3 MK3s kit) It was working find prior. I moved it and wanted to print. Now it says " Self Test Error - Please Check Axis Length - Axis X. But I can't figure anything out. As far as I can see everything is OK ?!?!? Tried calibration but it can't find calibration point.
Respondido : 03/12/2020 6:57 pm
JaDeeeee
(@jadeeeee)
RE: Fails self test and won't calibrate - says it can't find point.
..same problem here, I havent been printing fot half a year now, and started out this week to solve the problem. Actually the first layer calibration and xyz calibration works, but some of the other calibrations dont work. Test prints with real easy models do work out, but more detailed ones fail. The PLA starts to glue to the nozzle and clups all around it... after a while...    and I have no idea why... z-axis seems to be calibrated just fine. Temperature ist 215 degree as the printer suggested.
If anyone could tackle this and give some tips, this would be great!
Cheers and thx camel-2 for asking!
Respondido : 04/12/2020 4:34 am
Miembro
Check your Pinda height and could have damaged the Pinda or cable.
Respondido : 04/12/2020 10:08 am
