Failed x axis bearing
bo-10
(@bo-10)
How can I get a replacement X axis idler bearing?
My i3 MK3 is fairly new and it looks like the idler bearing has failed already.   The idler was squeaking and when I investigated I saw what looks like it coming apart.  The bearing is frozen and the idler is now turning on the mounting screw.    How can I get a replacement?
Opublikowany : 30/10/2020 12:21 am
RE: Failed x axis bearing
contact Prusa through the Chat option on the E shop page.
I am not happy about the single bearing idler that Prusa supply so I use ebay twin bearing idlers, 20 tooth diameter, 6mm belt width with a 3mm bearing hole, and I have not had a failure since...     I use the toothed version, there is also a smooth version which should be OK if you prefer to keep the smooth surface
Opublikowany : 30/10/2020 2:13 am
bo-10
(@bo-10)
@joantabb
Thanks!  What specs should I search for on ebay or Amazon.
Opublikowany : 30/10/2020 2:21 am
bo-10
(@bo-10)
"20 tooth diameter, 6mm belt width with a 3mm bearing hole"
Wait, let me try this first.  Thanks again.
Opublikowany : 30/10/2020 2:22 am
