Extrusion starts to have problems during prings
Hey guys, I'm trying to troubleshoot this issue (see pics) any suggestions the best way to start? It looks like it does well for a while, then I occasionally hear the dreaded exruder skipping' grind. Fans are both working, standard grey PLA at standard settings...
Publié : 07/04/2018 5:46 am
Re: Extrusion starts to have problems during prings
I just came across a post I put in a notepad on this subject. This is a good video on improving your 3d prints.
Search String: improving your 3d prints
Publié : 07/04/2018 6:15 am
You may have a similar problem to mine. I run into extruder clicks and skipping, but only when using g the silver from Prusa, and only then if I am trying to print <0.1 layer height. Please share if you find a solution.
Publié : 07/04/2018 12:46 pm
